If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I am definitely not an expert in any way - but is there any reason why the top of the "S" and the bottom of the "4" and the "zero" are missing??? Has anyone else seen factory stamped examples as such??? Do the broach marks look good??? Thanks.
