If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
1967 435hp Engine Stamp Pad - is this stamping legit or an imposture?
Regarding the attached 1967 435hp Engine Stamp Pad, please chime in, is this stamping legit or an imposture? Thank you in advance. 67 435hp red engine stamp.pdf
