Question re my vented gas cap - NCRS Discussion Boards
  • Stephen R.
    • May 20, 2008
    • 302
    I asked this question over on the CF. I'd like to get some thoughts from you guys here.
    http://forums.corvetteforum.com/c1-a...d-gas-cap.html
    • 15679
    Re: Question re my vented gas cap
    ...how about the courtesy of repeating the question instead of expecting everyone go to that "other forum" to find out what it is.
    • Dino L.
      • February 1, 1996
      • 694
      I have never taken one apart, but there may be a brass spring beneath the paper gasket and 3 spot weld stamping that works like a radiator cap...Don't flame me.....it is just a guess on my part.
      Dino Lanno
      • Stuart F.
        • August 31, 1996
        • 4676
        Let's see; I have two vented gas caps for my 63 (make that three). My original has just one small hole clear through it. My GM replacement, which is currently still available, has both a vacuum valve and a pressure relief valve. This is the best design possible for my car and is what I use today. My third cap is a nice chrome locking piece which I bought from my local Chevy dealer years ago. It too has just a small vent hole in it. I use it at shows only.
        There now, what's more to know about caps?
        Stu Fox
        • Stephen R.
          • May 20, 2008
          • 302
          Duke, is it that difficult and time consuming to press a button?
          Stu and Dino, thanks for the suggestions and ideas.
            • 43222
            Stephen------
            Well, I "pressed the button". In fact, I did it three times but it never took me to a post on CF with your question.
            • Stephen R.
              • May 20, 2008
              • 302
              Before I post anything with a link, I try it out first. When I go to my initial post above and click on the link, it immediately goes to my question (with the pictures) on the CF. I have no idea why it doesn't work with other member's computers. However, got my answer to my question.
              I have added a link below, again, it works for me.
              C1 & C2 Corvettes - Question re my vented gas cap - I have a clearly marked FE vented gas cap that's been on my car since 1974. For the life of me, I can't find the vent holes or how it's vented. Is it possible that it's mis-marked? I've attached a few pics. Would like opinions. Steve
              • Terry D.
                • May 31, 1987
                • 2692
                Stephen Is it that difficult and time consuming to type out the question? Have a little respect when you are asking for free information!!
                • Dave S.
                  • August 31, 1992
                  • 2925
                  I could,t agree more. This is why many don,t bother to respond on this Forum.
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    Stephen;
                    One reason I, and perhaps others, are not inclined to go to a link posted in a thread is because I get dropped off from the TDB and have to sign on again. I don't recall this was the case with my old Microsoft/HP PC, but now I am using my Apple IPad a lot and that is what happens. I have not tried it with my new Apple lap top yet, but I prefer the iPad.
                    Stu Fox
                    • Stephen R.
                      • May 20, 2008
                      • 302
                      It's the elitists attitude here that prevents people who aren't part of the "clique" from asking intelligent questions. All it takes is one member making a non-substantive response, then the "teachers" pile on.
                      For those who did respond above with some actual information, I thank you.
                      • Terry D.
                        • May 31, 1987
                        • 2692
                        And people in glass houses should refrain from throwing stones. It's funny that you have time to type comebacks but find it beneath you to type a legitimate question out.
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          Stephen
                          Here is an old discussion https://www.forums.ncrs.org/showthre...vented-gas-cap. Do not know if that will help you. Also at the bottom of any discussion there is a box that will have "similar threads" many times the answerer to your question maybe there. Also at the bottom of that similar discussion may have another match. Hope that helps.
                          • Stephen R.
                            • May 20, 2008
                            • 302
                            Stephen
                            Paul:
                            Thanks for the response, very helpful AND your link works, just one small push of a button for a man and one giant leap for........others.
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              I'm not sure yet what year we are talking about, but I can relate my recent experience with a 62; it does have a vent with hose and should not have a vented cap. C-1 tanks apparently don't have any baffles inside so the fuel tends to slosh around and will spill out specially on right hand turns causing a strong gas odor inside the car. Even caps with a fiber type gasket will not contain it. We had to get a cap from CC that had a rubber type gasket.
                              Stu Fox
