1991 fuel injectors - NCRS Discussion Boards
1991 fuel injectors
  • Paul M.
    • June 12, 2012
    • 83
    1991 fuel injectors
    Will a car start with bad fuel injectors? My buddy's car will start but when you apply gas it stalls. It's not the ecm because it has been replaced. Any help out there!!!
  • Guest
    Re: 1991 fuel injectors
    Paul I had the same problem with my 89 If you have bad injectors on both engine banks the ecm will not let the engine run.
    I replaced all 8 injectors . The company is Fuel Injection Components I believe they are in Georgia There have been threads about injectors with their info
    Mark
