Can the radiator and core support be pulled from below if the front cross member is removed first?
1969 BB radiator removal
Re: 1969 BB radiator removal
roger------
In this case, I don't think you can "kill two birds with one stone". However, having the crossmember out may ease the radiator replacement effort.In Appreciation of John Hinckley- Top
not 100% sure but I think the core support is not perfectly square (a little wider at top) so that would make slipping it down difficult.
Also - think the sway bar assembly would have to be completely removed and the front bumper horseshoe too.
basically - don't think so but who knows.. :-)
I would just take the hood off and take the radiator out from up top. it works. :-)- Top
