C2 Power Antenna Replacement Procedure - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hello;
    I recently purchased a restored (original) power antenna unit for my 65' with under-car exhaust'. Vehicle currently has a reproduction unit with a 9 inch mast, to remove. Can this removal & installation procedure be done without removing the rear valence panel & muffler ? Garage is equipped with a four post drive on ramp lift. Thank you.
  • Scott G.
    • August 31, 1984
    • 132
    Re: C2 Power Antenna Replacement Procedure
    The muffler is going to have to come off. The rear valance can stay in place.
    • Frank E.
      • May 31, 1986
      • 189
      I've had mine out many times. I remove the rear valance and disconnect the muffler from the hangar. I can push the muffler out of the way and remove/install the antenna ..... No problem
      I should also say that the exhaust tip needs to be removed.....
      Frank
      1966 Milano Maroon Roadster
      2004 CE Z06
      • Greg T.
        • January 1, 2004
        • 136
        Hopefully a file is attached.
        • Greg T.
          • January 1, 2004
          • 136
          If you have a repro in the car now it probably has an 1/8 inch antenna cable pin. The original will have a .085 pin. You will probably have to manually crimp the antenna cable sleeve to get a good connection. The 1/8 pins tend to stretch out the mating connector.
          • David K.
            • 281
            Thanks guys; I think I'm going to leave this project for next season. Going to drive the car before the bad weather sets in; this fall.
            • Scott G.
              • August 31, 1984
              • 132
              Good info on the procedure. I don't remember loosening the exhaust panel but it has been a very long time since I removed one.
