M20 vs M21 - NCRS Discussion Boards
M20 vs M21
  • Greg Y.
    • April 3, 2014
    • 25
    M20 vs M21
    I'm trying to determine which of these I have in my '66 coupe. According to the Black Book approximately 11 thousand of the M20's were installed and 14 thousand of the M21's in 1966 so it's about a toss up. Is there an accurate way to tell which one I've got? Does each have a specific part number?
    Thanks in advance
  • Keith B.
    • March 7, 2008
    • 928
    Re: M20 vs M21
    If it's the original trans there will be numbers stamped on the housing. Also there is small metal tag with a part number stamped on it.
      • 43222
      Re: M20 vs M21
      Keith-----
      For the 1966 model year there was no stamping on a Muncie that identified whether it was an M-20 or M-21. However, if the part number tag is still affixed to one of the side cover bolts, that will identify it.
      • Mike T.
        • January 1, 1992
        • 568
        Re: M20 vs M21
        This isn't a definitive way to figure out whether you have a wide or close ratio trans but isn't it more likely that if the rear gear is higher numerically, like 3.70 or 4.11, then the transmission would typically be close ratio (2.20 first gear)?
        Mike T. - Prescott AZ.
        • Jim T.
          • March 1, 1993
          • 5351
          Re: M20 vs M21
          What engine came in your 1966? My 1968 has 327/350HP M21 and 3:70 rear end.
          • Jim L.
            • September 30, 1979
            • 1808
            Re: M20 vs M21
            How to determine if your transmission is wide or close ratio:
            Travel in 4th gear with engine turning exactly 1000 RPM. Note your speed.
            Shift to 1st gear and bring car back up to the previous speed. Note the tachometer.
            If tachometer indicates 2540 RPM, you have a wide ratio box.
            If tachometer indicates 2200 RPM, you have a close ratio box.
            Simple. Easy to remember.
            Jim
            • Greg Y.
              • April 3, 2014
              • 25
              Re: M20 vs M21
              Jim
              Bingo... I'll give that a try. Thanks to all who responded.
