T-stat sticking partially closed??? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2675
    I am suspicious that the thermostat on my '64 Corvette with 327/300 may be sticking and causing the car to run warmer than usual. Today it registered about 190 on the gauge driving in town and on the highway. Ambient temp was 82 degrees. Just completed a coolant change and all hoses replaced before leaving for KC. I did not change the t-stat and installed the same one back in with the water flow going from the radiator to intake manifold. That is the right direction for normal water flow... correct???
    James West
    • 43285
    Re: T-stat sticking partially closed???
    James West
    James------
    190 degrees on an 82 degree day does not sound unusual to me.
    The thermostat should be installed with the end with the spring oriented DOWN.
    I prefer Robertshaw-style thermostats.
    • James W.
      • December 1, 1990
      • 2675
      Joe,
      Does the coolant flow from the to radiator outlet to the intake manifold? I installed the t-stat orient so that when you pressed on it it would open towards the ground or into the intake manifold.
      James
      James------
      • Mike T.
        • January 1, 1992
        • 570
        James - I also think your 190 on an 82 degree day sounds okay. Have you verified the temps with an IR gun? If you feel the engine is running warmer than before under these conditions, what temps have you seen in the past? By the way, the flow of coolant is 'out' of the engine at the top and back 'into' the engine at the bottom.
        Mike T. - Prescott AZ.
        • John F.
          • March 23, 2008
          • 2423
          You can test it on the stove in a pan of water. It should open before the water boils.
          • Domenic T.
            • January 29, 2010
            • 2452
            I've read a few posts lately and it just came to me that all (equal temp) thermostats do not have the same sized outlets.
            They do not all pass the same amount of coolant to the radiator when fully open.
            DOM
              • 43285
              DOM
              DOM------
              That's why I recommend the Robertshaw type.
              • Steven B.
                • June 30, 1982
                • 4013
                Joe,Does the coolant flow from the to radiator outlet to the intake manifold? I installed the t-stat orient so that when you pressed on it it would open towards the ground or into the intake manifold.James
                James, pointy end up. Steve
                • James W.
                  • December 1, 1990
                  • 2675
                  Thanks to all who have replied. From memory I did install the t-stat with the pointy side up. I am wondering if my fan clutch is starting to go? I am also going to re-check the timing.
                  Thanks again,
                  James West
