59-60 FI guys Need Help!!!!! - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 688
    Can I get someone with a 59 (preferably) or a 60 Fuel car to post close-up pictures of the accelerator rod bracket (that wide thing that the accelerator pedal rod attaches to at the firewall) and the linkage that connects to it and the bellcrank? I'm trying to determine if my bracket is correct. Mine is positioned so far forward, I can't adjust the bellcrank throttle rod to achieve WOT. John D. and I seem to think the issue may be with area-- can't find any detailed pictures of the bracket position. Thanks All. Al
  • Al R.
    • June 30, 1988
    • 688
    Re: 59-60 FI guys Need Help!!!!!
    Am I the only one with a 59 FI car in the NCRS? Surely someone else has 1 that can provide the pictures. Thanks!!! Al
    • Loren L.
      • April 30, 1976
      • 4104
      Noland's book? Somewhere?
      • Don H.
        • December 1, 1981
        • 1499
        Al, I tried but it is very difficult without taking it apart. Perhaps someone that has theirs apart will get better pictures. I was going to post what I had but the system will not allow me to upload them (they are less than the maximum allowable size so I don't know why). Don H.
        • Al R.
          • June 30, 1988
          • 688
          Loren, I 've checked, but did not see what I need. Donald, thanks for trying. The main thing would be to see the position or angle of the bracket (with pinchnut bolt) in relation to the top of the engine, so I can possibly tell if mine is correct, as it is positioned too far forward toward the FI unit or if I have other issues. Again, thanks for the response! Al
          • Al R.
            • June 30, 1988
            • 688
            Guys, here's what I have - need pictures of anther 1 or 2 59-60 to compare by Thanks All l
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11366
              Al, I have the original unit bellcrank for the '61 FI I'm restoring here. Is that the same part as 59-60? Engine isn't back in yet but I have the original pedal throttle rod and bracket loose in the beadblast pile. My FI throttle rod, however, is a repro. I can take some measurements and pics of what I have here loose if you think it'll help.
              Rich
              p.s. I'm wondering if your unit bellcrank is bent. That longest part of the lever looks a little "different" to me.
              • Don H.
                • December 1, 1981
                • 1499
                Here are a couple of pictures. (I had to go to another computer to upload.) The bell crank & arm are original, the rod is not. Don H.
                • Jim L.
                  • September 30, 1979
                  • 1817
                  Don, that bellcrank has a very long upper arm, consistent with what I see on '57-ish FI units. What FI model is that?
                  Al, check the picture I posted in your thread on CF.
                  Jim
                  • Don H.
                    • December 1, 1981
                    • 1499
                    Jim, It is a '60 320 unit. Although I have had it for a long time I am not 100% sure the bellcrank is correct. Don H.
                    • Al R.
                      • June 30, 1988
                      • 688
                      Richard, not sure if it is the same or not. I'm sure John D or Podell would know. The bell crank is a repo, however, when it is laid side by side with my original, I can't see any difference between the two that would change any lengths or angles.
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11366
                        Okay, Just wanted to check in if I could assist with more samples. Hope you figure it out as I may have a similar issue on this '61 eventually.
                        Rich
                        • Jim L.
                          • 1817
                          Al,
                          Here's the picture I posted on CF of the linkage on my FI unit. Compared to yours, the angle formed by the two bellcrank arms on mine seems measurably larger, which allows me to achieve WOT.
                          Don, this unit started life as a 7320 model, same as yours and the bellcrank for it, altho a repop, is like the original 7320 bellcranks I have.
                          Jim
                          • Al R.
                            • June 30, 1988
                            • 688
                            Jim, I did notice yesterday that with the choke off, the top of the bell crank goes toward the radiator a little more, which results in more angle similar to but not as much as yours. I decided to cut the end off the throttle rod that hooks in the BC and re-bend it. This will result in a shorter rod and more pedal. Found out the rod's a repo, so I guess it won't matter if Bubba shows up on this one. Al
                            • Don H.
                              • December 1, 1981
                              • 1499
                              Jim, I am not seeing a difference in my bellcrank & yours other than which side the rod attaches to. Don H.
